R18 trans. filter size, want to use a Magnefine
Does anyone know if the trans filter is 3/8" in/out? I want to change mine to a Magnefine
but want to be certain I get the right one.
EDIT: This is for an auto transmission.
Finally got around to update this.
The correct size Magnefine filter for the R18 is 3/8" inlet/outlet diameter.
Here are some pics and more info for anyone interested.
The Magnefine is about 1/2" longer than the OE strainer. I had to trim the feed hose to get it to fit correctly.
Make sure to get the real deal Aussie made Magnefine, not the Raybestos made in China crap you will see everywhere. Got mine here: http://www.emergingent.com/subpage1Magnefine.htm
The arrow in the pic shows the direction the ATF flows. I started the engine for a second and put a container at the end of the hoses to figure this out. This new filter is too big for the bracket by just a little. I ended up zip tying it shut.
Nasty old strainer @ 80k
