Wilwood Big Brake Kit - Front - Bleeding
Old Apr 11, 2014 | 05:23 AM
mdrouillard1983's Avatar
Default Wilwood Big Brake Kit - Front - Bleeding
Just picked up a set of front end brakes, Wilwood Calipers with SS lines and pretty excited, these are 4 piston calipers.
Bleeding them seems like is going to be a B*TCH as there are 4 bleeder valves, I think it is best to focus on top bleeder with a tube submerged into fluid? anyone have experience with this?
Last night attempted to bleed, no fluid was coming out; but dumb me forgot to submerge opposite end the tube - sounds like a stupid question just want to confirm. (with each pump on the brake pedal it forces out, and sucks back - I would want it sucking flud back in not air which leads me to believe this is why no fluid was coming out and getting no where)
Old Apr 11, 2014 | 07:51 AM
BLU CIVIC's Avatar
Track Advocate
Default Re: Wilwood Big Brake Kit - Front - Bleeding
google. found your answer there when i searched
Old Apr 11, 2014 | 08:02 AM
F22Master's Avatar
Sounds to me like you dint know how to bleed brakes....
Pump pedal 3-5 times, slowly, hold down.
Open bleeder, closer bleeder.
Repeat.
You don't need to submerge the hose end.
Old Apr 11, 2014 | 10:41 AM
Thanks guys, I know how to bleed brakes the conventional way; but how do you hold the brake pedal down, while simultaneously close the bleeder valve? A stick? LOL
The hose submerged in brake fluid is the one-person method I was referring to.
Thx
Old Apr 11, 2014 | 02:34 PM
F22Master's Avatar
You need a vacuum bleeder to do it by yourself.
Im sure there are other ways, but that is the correct way.
telekineticz
10
Sep 10, 2008 03:57 PM
Nessal
Sep 3, 2005 06:24 PM
Silvteg95
Aug 19, 2005 10:50 PM
Mattyg2
Sep 15, 2004 06:41 PM
RCautoworks
Apr 15, 2003 08:53 PM
