99 honda accord ex starting problem
Old Apr 10, 2014 | 06:24 PM
busdriver1191's Avatar
Default 99 honda accord ex starting problem
I have a 99 Honda accord ex with a 3.0 v-tec motor and it has a problem I think it might have something to do with the security system, my scanner wont pick up any codes when its not starting, the key will flash on dashboard. when its running my scanner reads there are no dtc codes. I replaced the map sensor , and when its running it surges but if you apply the gas pedal aggressively its fine until higher rpms. could I get some help with this problem.
Old Apr 10, 2014 | 09:41 PM
holmesnmanny's Avatar
Default Re: 99 honda accord ex starting problem
Sounds like something is wrong with the immobilizer. You can either go to the dealer or find a reputable honda repair shop.
Old Apr 11, 2014 | 02:24 AM
are you talking about the ecm?
Old Apr 11, 2014 | 06:19 AM
the reason I thought it was something with the security was because it wil start but shut off immediately when it wont start. so I guess if it is the immobilizer its kinda the same thing cause don't you use the immobilizer to reprogram the keys.
pgilger
Mar 26, 2012 07:15 AM
accord53
Mar 14, 2005 01:48 PM
