manual transmission fluid?
Old Apr 10, 2014 | 01:18 PM
MMMGIRL's Avatar
Default manual transmission fluid?
Just out of curiosity, I have a ls trans that needs fluid changed asap. I have some pennzoil 15w-40 around, can I use that as the fluid? I understand the viscosity could be amn issue but I used 10w-40 last time and they are both 40 weight oils. Any input?
Old Apr 10, 2014 | 01:25 PM
B_Swapped93's Avatar
Default Re: manual transmission fluid?
sure no harm done, just recommended you change it sooner then if you used Honda MTF.
Old Apr 10, 2014 | 01:39 PM
motocrossracer9's Avatar
I was wondering the same thing I'm drawing mine now I got 80w90 gear oil will that work ?
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Is an LS Manual Tranny different? I've always been told either 10w-30 or Torco MTF as better options instead of Honda MTF for my manual tranny (D-series).
Old Apr 10, 2014 | 01:40 PM
that seems rather HIGH lol 80/90 but I'm not sure if gear oil goes by the same properties it should tho.
@tomcat nope just a long gear b-series trans
Old Apr 10, 2014 | 01:42 PM
That's what smelled like what was in it . What should I get then motor oil or a thinner gear oil
Old Apr 10, 2014 | 01:43 PM
JoeBlue's Avatar
Amazon.com: Genuine GM Fluid 88900399 Synchromesh Friction Modified Manual Transmission Fluid - 32 oz.: Automotive Amazon.com: Genuine GM Fluid 88900399 Synchromesh Friction Modified Manual Transmission Fluid - 32 oz.: Automotive
Old Apr 10, 2014 | 02:07 PM
P-M-B,93EXsedan's Avatar
I always hear GM synchromesh is best fluid. Everyone IV seen with an accord 6speed has been happy with this fluid
Old Apr 11, 2014 | 05:24 AM
kyden's Avatar
80w90 is going to destroy your transmission.
Old Apr 11, 2014 | 06:06 AM
turbomaniac's Avatar
check your owners manual.
dont do things because you see others doing them...
if you dont have the owner's manual downoad it from the internet
SheepDawg
20
Feb 11, 2013 12:57 PM
tmugg
Oct 20, 2008 12:09 PM
07galaxygrey4dr
Honda Civic (2006 - 2015)
21
Jul 27, 2007 10:12 AM
petrv
May 30, 2003 01:56 PM
Ignitecivic
12
Apr 4, 2002 02:04 PM
