will accord LBJ fit into prelude knuckle?
Old Apr 10, 2014 | 08:36 AM
ailachami's Avatar
Default will accord LBJ fit into prelude knuckle?
will a 94-97 accord lower ball joint fits into a 96 prelude vtec knuckle?
Old Apr 10, 2014 | 09:14 AM
accordturb96's Avatar
Default Re: will accord LBJ fit into prelude knuckle?
Just use a honda parts site and compare part numbers
Old Apr 10, 2014 | 01:10 PM
ailachami's Avatar
i know part numbers are different and accord LBJ bolt is 17mm vs prelude 19mm. im swapping the brakes and knuckle assembly to prelude vtec. instead of reaming the lower control arm for the accord to fit prelude LBJ, i can just swap out the ball joint and call it a day.
Old Apr 10, 2014 | 01:31 PM
MAD_MIKE's Avatar
MM Gruppe B
Grab some measureing calipers.
Go to the parts store.
Ask for a Prelude LBJ and an Accord LBJ.
Only use a BJ that has a smooth outer case, not the teethed type.
Measure the diameter, and measure the distance(height) of from the lip to the spiral lock groove, of the BJ base. Also measure overall cone height of the BJ stud.
If the heights are different then that would induce bumpsteer and reaming would be the ideal thing to do.
If all the measurements are the same, then you most likely can use the one BJ in place of the other.
Old Apr 11, 2014 | 06:43 AM
1native's Avatar
Go to the parts store with the info from both Cars .ask for the parts #. If both are the same then yea.
Old Apr 11, 2014 | 08:30 AM
ailachami's Avatar
went to the dealer and compared both. the prelude is a little bigger in diameter than the accord, the height is the same.
helldriver88
Sep 18, 2010 06:37 AM
redtech
Mar 6, 2006 03:01 PM
yamaha-sc500
Dec 2, 2005 03:58 AM
