need replacement strut mounts for koni yellow sport
for my 2000 accord EX-L 4cy auto
i need to know where or even if i can get new ones to fit my know yellow or if i'm boned and need all new struts
the top nuts, washer, bushing and spacer rod all came loose and fell off, problem is the rod on my koni seem to be bigger diameter than stock. autozone has oem spec mounts, i could maybe drill out the washer, but what do i do about the spacer besides cut out out of a like a pipe nipple???
i put some grade8 washers and a nut on that strut to hold it together and 0 reinstalled all 4 oem struts.
i know koni has a lifetime warranty except i'll admit i'm not the original owner and idk where the hell they originally came from, so its probably not even worth barking up that tree.
missing the lowered ride one neuspeed/koni, it was way faster to just revert to oem, and i must admit i like the quietness and comfort, which is why i'm thinking of doing dropped yellows on oem springs. (the back has about 90lb of sound equipment and the gas is always around 3/4 so its weighed down a bit. dropping the front strut will be about perfect)
3doorin
Suspension & Brakes
11
Feb 25, 2011 05:32 AM
