Mid-Atlantic (Sales) VA, DC, and MD
90 Acura Integra Parts. oem and aftrmrkt B18
Old Apr 8, 2014 | 05:08 PM
claymonthug's Avatar
Default 90 Acura Integra Parts. oem and aftrmrkt B18
!!!!!!!!!!!!PICK UP ONLY!!!!!!!!!!!! 19809
parting out a 90 integra with extras!!! car was hit in front and is missing head lights, rad, front bumper and condenser. everything else is there. if its not listed call or send a txt. i will sell nuts and bolts, vents, covers, speakers, steering wheel. etc just ask. nothings out of the question.
!!EVERYTHING IS OBO!!
i dont believe in 'low ballers' its called asking for a deal and there is no shame in that game. dont be afraid to ask. Call Kyle 443750onetwofivesix
i have pretty much evrything you need to do an LS swap on an EF civic. the only thing missing is axles and a transmission
B18A1 engine.......... 550 fresh partial rebuild! (new head gasket, decked, valve seals, angle job and adjustment. its a little dirty on the outside but VERY clean internally. owner let distributor O-ring leak even after having the motor rebuilt) **rebuild is so new there isnt even any carbon on valves** BLUE VALVE COVER.
obd0 uncut engine harness..... 50
distributor......... 50
pr4 ecu....... 50
mid shaft/half shaft/intermediate shaft ...... 40
transmission cable (needed for ef swap)..... 40
throttle cable (also needed for swap)..... 40
shift linkage with short shifter........75
shift linkage without short shifter....... 50 (NOTE: if you are buying for EF swap it needs to be shortened by about 3 inches)**** i will cut and weld for an extra 20
short shifter (dont know the brand but it looks like a B&M dual bend) the one on my personal car is half the quality of this one)....... 50
starter..... 40
tail lights...... 30 each
rear bumper in primer grey..... 50
front seats, blue in good condition... 40 each or 60 for both
dash (black in good condition)...... 100
rear trailing arms with brake cables (for civic drum to disc conversion)....... 150
front hubs with calipers...... 50 each
brake booster with master cylinder (not abs)..... 40
brake proportioning valve (really helps if you do drum to disc conversion)........ 20
!!!EXTRAS!!!
carbon fiber hood...... 100 (NOTE: has damage from accident. *missing latch needs to be pinned or have a latch attached to it)
Lowering Kit. kyb struts eibach springs....... 250
hasport ef swap mounts for cable transmission.......... 250
DC 1 piece long tube headers in ok condition..... 50 (currently on my car)
DC 4-2-1 ceramic coated headers in great condition....... 175 ($341.80 new)
Skunk2 full cat back exhaust........ 200 ($507.14 new) built for 90-93 integra but can be modified easily to fit 88-91 EF and a few other civics/ integras (has some surface rust but its in great condition)
ram air intake with filter......... 30
**i also have a coplete 00 civic si B16 head**
NOTE: i will send pictures directly to you of anything you are interested in as well. just ask. (i will only send them through txt msg)
443-750-one2five6 ~ kyle
NewCarScent
Jan 23, 2015 03:27 PM
burnsmonkey
Southeast (Sales)
Aug 13, 2014 08:34 AM
claymonthug
Apr 4, 2014 05:03 AM
