Alternator Pivot Bolt Loose
Old Apr 8, 2014 | 02:14 PM
Fishbone Fan's Avatar
Default Alternator Pivot Bolt Loose
1998 Civic EX stock D16Y8, Manual Trans.
While I was doing an oil change and PCV valve replacement I notice my alternator's pivot bolt was loose and had about a 1/4" to 1/2" of play side to side. Is this normal?
My first instinct was to tighten it, but I didn't because I didn't want to create undue tension or drag. Please respond.
Old Apr 8, 2014 | 04:14 PM
Default Re: Alternator Pivot Bolt Loose
bump
Old Apr 8, 2014 | 04:45 PM
NotARaCist's Avatar
I never narc'd on nobody!
Are you talking about the center point bolt, that the alternator rotates around, or the set bolt, that keeps it from rotating?
Old Apr 8, 2014 | 05:47 PM
JoeBlue's Avatar
Hmm, bolts vibrating lose on their own, nope that is normal for a Civic. Especially one of such vintage. Tighten to spec and move on, if it happens again maybe consider using locktite on it if it bugs you that much. Just be away that this could make things harder to pull apart in the future.
Old Apr 9, 2014 | 03:48 AM
Thanks. It is the bottom bolt the alternator rotates/pivots on. I will tighten to spec and loc-tite it.
sleepa
Jun 3, 2008 04:31 AM
Xuelor5
Mar 9, 2008 05:09 PM
RJL
Sep 20, 2001 07:10 PM
