Accord Sway Bar Suggestions??
Hello all. Looking for suggestions regarding sway bar kits for a 2000 Accord. I am currently running Koni Yellows/Ground Control with 18" Racing Hart C5's. I have a Neuspeed strut tower brace, although I think it's mostly for looks. Looking to upgrade the front and rear sway bars and have looked at Suspension Techniques' setup. Not bad for under $400. Looking to make the ride tighter with less roll. Any feedback would be greatly appreciated. Thanks!!
The tl type s has got a 19mm rear sway bar and the regular tl has a 18mm rear sway bar.
Check this website out
http://www.hondanews.com/channels/290/releases/d7651cf2-110d-016c-9454-7c004c34c75c
@M3THTICAL(EF), thanks I appreciate it. Interesting reading. I think I may go with a Suspension Techniques setup for the rear. The rear is the same 19mm thickness as the TL Type S. Might go with the Type S for the front though, as it's a 27mm bar compared to ST of 23mm.
