Car vibrates when stopped parked or reversed HELP
Old Apr 6, 2014 | 02:45 PM
minorityxunit's Avatar
Default Car vibrates when stopped parked or reversed HELP
•1990 Honda Accord
•150k+ miles
Car vibrates/shakes when stopped, parked and reversing?
Can anyone tell me why my car does that? But does anyone know the for sure thing that makes my car vibrate? I heard it might be the brake calipers? If someone doesn't know forsure? Can some give me a list of items and it can be. Thanks in advance
Old Apr 6, 2014 | 03:04 PM
whiterice916's Avatar
10 Year Member
Default Re: Car vibrates when stopped parked or reversed HELP
Originally Posted by minorityxunit
•1990 Honda Accord
•150k+ miles
if you mean that the car vibrates when you're stopped at an idle with it in gear and gets a little better in neutral then go change what motor mounts are broken. It can't have anything to do with tires or brakes unless it only vibrates or shakes when moving. if its only when moving then check those two things but brakes only pulse when you push on the pedal and you have a warped rotor or maybe a loose caliper.
the main reason for any Honda to vibrate when its sitting at an idle is motor mounts. Every single Honda in this world will vibrate at one time in its life. put new FACTORY mounts in and you're good.
Old Apr 6, 2014 | 03:17 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
new mounts is all,
Old Apr 10, 2014 | 12:41 PM
VegasInvasion's Avatar
I'm Huge In Japan
*moved thread, not performance related.
Old Apr 11, 2014 | 04:53 AM
simbabeat's Avatar
Motor mounts. And you can spend a ton of money on those and you'll still have some vibration. It's an old car.
minorityxunit
Suspension & Brakes
May 14, 2014 02:05 PM
duffman1278
Jul 4, 2008 06:27 AM
vietkangta
Apr 22, 2007 09:28 PM
pbjs0104
Jan 26, 2006 03:22 PM
TegRyan
Sep 24, 2005 02:54 PM
