96 civic D16Y7 start/running issue
Old Apr 5, 2014 | 02:11 PM
Smoked_Peasant's Avatar
Default 96 civic D16Y7 start/running issue
We're at our wit's end over this.
Initially, car would turn over but just wouldn't start. Figuring it was a bad coil, we tested it. Out of spec so we replace that, along with cap, wires, & plugs (they were old), No Bueno. Testing the spark, only getting good spark from three of the plugs, plug one gives off a weak yellow spark. Until we tried without a plug in no.2, now we get good spark in no.1. still haven't solved that, but we tried looking at other things as well. Timing belt, compression, fuel regulator, engine ground...
It's not throwing a cel.
We have gotten it to at least idle (barely) backfires badly, eventually stalls.
We replaced the entire distributor, all the engine grounds... out of ideas.
Any suggestion?
Old Apr 5, 2014 | 04:18 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 96 civic start/running issue
96 civic with what engine? Any mods or is it stock?
Old Apr 5, 2014 | 06:04 PM
The regular 1.6L non v-tech. It's stock.
Old Apr 5, 2014 | 08:54 PM
carlos8's Avatar
Do you check if battery voltage is getting to the positive in the coil and ignigtor.
Old Apr 6, 2014 | 12:15 AM
KiNGDEE206's Avatar
Default Re: 96 civic D16Y7 start/running issue
whats the compression ##'s
Old Apr 6, 2014 | 08:56 AM
It's getting voltage, but I'm not sure that was checked.
140-160 across all of them, no more than 20 between any one of them.
Old Apr 9, 2014 | 10:32 AM
Guess I need to bump this thread.
bismoracing
Dec 6, 2015 03:21 PM
Steveojonez2112
Jul 24, 2012 03:55 PM
Texspace
11
Apr 29, 2011 11:50 AM
loghead209
Apr 23, 2011 07:52 PM
Puscifer
Jul 28, 2010 01:12 PM
