Possible Swaps in EJ8 (Tucson, AZ)
So I have a 96 EJ8 with an obd1 "mini-me" d16zc block w/ d16z6 vtec head, wont pass emissions. So im looking to get some info on what the cheapest motors i could throw in to have a solid daily that will pass emissions. Its still got the original obd2 harness, not sure if its that hacked into or not. I'm located in tucson arizona and i dont think i have the experience to do it myself, so does anyone know of a reputable engine shop in the tucson area also? Thanks for any input
Swap out oil pump, crank sprocket, and lower timing cover for a Y7/Y8 unit.
Install crank sensor
Use Y8 EVAP components & fuel rail
Go back to OBD2
Leave the top timing cover off or rig it to fit.
Roll around with two dipsticks.
There might be something I left out, but that's probably a lot easier/cheaper than swapping an entire engine.
Go back to OBD2
jimmy o.
May 10, 2010 04:44 AM
raplum
Sep 15, 2009 09:57 AM
mike_belben@yahoo.com
Nov 23, 2005 02:41 PM
