front lca question on ek's
Old Apr 5, 2014 | 04:41 AM
92bseries's Avatar
Default front lca question on ek's
Researched and Googled and didn't find what I wanted so posting here. Wondering if the front lower control arms are interchangeable between coupes and sedans. I'm finding sedans that are being parted but no coupes. I have an em1 so dont know if I need a front lca from an ex/si or if one from a sedan would work.
Old Apr 5, 2014 | 04:51 AM
B_Swapped93's Avatar
Default Re: front lca question on ek's
it won't have the sawybar end link mounts if it's a sedan base model, idk if any sedabs cane with a sway bar(s) for that matter.
Old Apr 5, 2014 | 07:27 AM
spAdam's Avatar
Loved
Community Favorite
EX and LX sedans did at least, can't speak for DX & VP though.
But otherwise, the suspension is not body dependent. You can swap between all 96-00.
Old Apr 5, 2014 | 10:23 AM
HondaPartsHero's Avatar
Technical Hero
CX/DX
51350-S01-A00 right
51360-A01-A00 left
EX/LX
51350-S01-000 right
51360-S01-000 left
[/img]
Si
51350-S04-A10
51360-S04-A10
Old Apr 5, 2014 | 12:54 PM
spAdam's Avatar
Loved
Community Favorite
Curious, I wonder what the physical difference is between the cx/dx and lx/ex arms, they both have sway bar provisions. Bushing material perhaps?
That reminds me though, I believe you have to use Si forks with the stamped arms, you'll definitely have to get creative with the end links if you retain the stock bar too (maybe gsr upside down?)
Edit: I didn't notice OP saying he had an Si. You need an Si arm.
Old Apr 5, 2014 | 01:41 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
CX/DX arms don't have sway bar holes they're cast iron.
EX arms have swaybar holes and are cast iron.
Si/CTR arms are welded steel and they're hollow. They're 1Pc. They have different bushings and a totally different type of sway bar mount. They also have wider shock bushings so they require different swaybars and different shock forks/bolts.
Old Apr 5, 2014 | 02:14 PM
Why are the Integra DC ones a 2pc design ?
Old Apr 5, 2014 | 02:38 PM
B serious's Avatar
Probably because they were designed in 1992...they worked on 92-95 civica...so they wanted to keep the working design for 94-01 integras. Not sure why they didn't do special arms for the ITR. Probably because it wasn't worth it.
The only ones on the 96-00 civics that are 1pc are EM1/CTR arms. The rest are 2pc.
Old Apr 5, 2014 | 06:24 PM
tony_2018's Avatar
Fish Twig
No one knows the answer to thats but Honda engineers.
Old Apr 6, 2014 | 04:45 AM
spAdam's Avatar
Loved
Community Favorite
That's what I thought but the above diagram was showing me different.
Old Apr 6, 2014 | 08:12 AM
tony_2018's Avatar
Fish Twig
I find it strange that from 96-97 they show a different swaybar setup. 98-00 have the same setup.
Old Apr 7, 2014 | 09:46 AM
92bseries's Avatar
Guess I'll have to find em1 lcas since the diagrams differ. O well no biggie. The one I got from the store didn't have the sway bar end link attachment for it so guess I'll have to find an em1 being parted or get new ones. Yikes
Old Apr 7, 2014 | 09:59 AM
kyden's Avatar
you'll have to find em1 ones or CTR if you somehow come across them.
Old Apr 7, 2014 | 11:42 AM
B serious's Avatar
You can buy CTR arms at a JDM supplier. CALL to ask somewhere like hmotors or jdmenginescorp.com. they probably don't list them on the sites.
Or...buy new EM1 arms from Honda. I think bernardiparts.com had them at a fairly affordable price.
Old Apr 7, 2014 | 11:43 AM
spAdam's Avatar
Loved
Community Favorite
You can get new aftermarket for a reasonable price, then you get new bushings too. Hardrace are ~$250 for the pair with all lower bushings, Moog are a bit cheaper iirc.
Old Apr 7, 2014 | 01:27 PM
92bseries's Avatar
I got mine from OReilly w/ bushings for 130. But it didn't have the sway bar end link attachment so it's just kinda hangin there. I'll more than likely buy 2 different ones for an si powder coat them and put polyurethane bushings in them
rickypwp1985
Feb 6, 2009 10:17 PM
wantboost
Nov 10, 2005 10:00 PM
2 point 0
May 18, 2004 09:39 AM
fowler!
Nov 9, 2002 06:20 AM
'99 HB Hank
Aug 22, 2002 07:55 PM
