whats the biggest tires i can use??
Old Apr 5, 2014 | 03:45 AM
roachownsu's Avatar
Default whats the biggest tires i can use??
I got a 1999 honda civic ex..i just bout some used 17x7 in rims.. The tires that came on them are a little small..they sre 205/40/17....now i know i need new tires but im trying to figure out wat size i should go with to fill that wheel well up...btw it has stock supension.....any inputs? I was thinking maybe a 225/45/17..but i just dont know ifthey will rub
Old Apr 5, 2014 | 05:05 AM
cetcivic's Avatar
no one wants to hear the truth
Default Re: whats the biggest tires i can use??
http://tire-size-conversion.com/tire-height-chart/
Old Apr 5, 2014 | 05:27 AM
j.red's Avatar
http://www.rimsntires.com/specspro.jsp
This is a fairly good tool for comparing tire and rim sizes.
Old Apr 5, 2014 | 06:17 AM
toyomatt84's Avatar
Sanji
Your car should dictate what size tire you run more so then your visual preference. Running too large or too small of a tire causes issues with the car's ability to drive, stop, and maneuver. 3% oversize/undersize on the overall tire circumference should be your upper and lower limit, when comparing to the stock tire size.
The biggest you could really go on those wheels are: 215/40/17's (205/45/17's are just outside the realm of 3%, but they're close)
Old Apr 7, 2014 | 05:50 AM
roachownsu's Avatar
Ook.....the fitment guide is basically giving me the size to the OEM wheel...but if I do get the sizes it tells me then I wouldn't be filling in the wheel wells....I would have to lower the suspension..and I don't have the cash for that right now.... I could use some more input on sidewall measurements to see if they would fit
Old Apr 7, 2014 | 02:56 PM
DaveSi677's Avatar
those are big wheels on an ek... most run 15 for better tire choice in terms of grip.
Old Apr 7, 2014 | 07:06 PM
toyomatt84's Avatar
Sanji
You can afford tires, but not a decent coilover setup?
Old Apr 11, 2014 | 12:31 PM
doc@tirerack's Avatar
205/50R17 or 215/45R17
Old Apr 23, 2014 | 03:36 PM
MidoriRhd's Avatar
i would do 225. have a friend running them now and they look nice and beffy. he has aftermarket susp. too.
boostit2120
Jul 28, 2013 06:16 PM
poseghatch
May 23, 2013 02:51 PM
danielboik
Jul 9, 2010 11:19 AM
boston71
Mar 14, 2010 05:03 PM
lodown414
Aug 26, 2002 09:06 AM
