99 ek b20b4 bearing issue
Which bearing? The wheels? If so, it depends on which knuckle/brake set you have (9.5" or 10.2") so we need to know more about the car than the motor.
If you are having to replace them frequently you are most likely over/under torquing them. You must use a torque wrench for this job.
