Suspension & Brakes Theory, alignment, spring rates....
Teggy rear disk
Old Apr 3, 2014 | 05:07 AM
kev8alot's Avatar
Default Teggy rear disk
This may seem like a super silly question but what rear disk breaks would go into a stock 97 ls, keeping abs. Or if you know of a write up please send me in the right direction. only reason im keeping abs is because of autox. All the posts ive seen have been civic conversions. Thanks
Old Apr 3, 2014 | 08:34 AM
redlinetuning's Avatar
Default Re: Teggy rear disk
Your 97 LS already has rear disk brakes. Just keep it stock, check your brake fluid, pads, and get some driving experience first.
Old Apr 3, 2014 | 10:32 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Just get good pads and tires!!! The front will handle most of the braking and heat. ITR calipers and Mini cooper rotors was a great direct bolt on upgrade.
Old Apr 3, 2014 | 11:23 AM
kev8alot's Avatar
Rofl, i can't believe i didn't notice that. Yea they are disk, i just checked, im a dutz. My brakes are fine then. Maybe you can help me with something else then. My ebrake was really loose 19clicks roughly, now i adjusted it so it was around 8-11clicks. Should my car move if i engage the ebrake and slowly let off the clutch and apply the gas. It may seem like my question is dumb and silly, but its something that they inspect i guess in mass and currently it does move. If this is ok and i got bad information great. If not what could the potential problems for this be. The brake pads aren't new but they aren't squealing.
TimeAttackR
13
Jul 11, 2018 08:38 AM
aw614
Oct 9, 2015 02:28 PM
JaredJCarpenter
Jan 5, 2007 08:59 PM
gsr1289
Aug 17, 2006 04:12 PM
ScootinIntegra
Feb 16, 2004 03:59 AM
