Problem finding Pistons
All depend in what you want to build. i.e. stock or F.I. But you can start with this: (note the first one says specify the bore size at order).
http://www.ebay.com/itm/1996-2000-1-6L-HONDA-CIVIC-DELSOL-D16Y5-D16Y7-D16Y8-SOHC-16V-PISTONS-SET-/370548478694?pt=Motors_Car_Truck_Parts_Accessories&hash=item56466912e6&vxp=mtr
http://www.ebay.com/itm/P29-HIGH-COMPRESSION-PISTONS-W-RING-75-5MM-D16A-D16Z6-D16Y7-D16Y8-HONDA-CIVIC-ZC/301105267684?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111000%26algo%3DREC.RVI%26ao%3D1%26asc%3D21022%26meid%3D5928237702646566267%26pid%3D100033%26prg%3D9336%26rk%3D1%26rkt%3D4%26sd%3D301105267684
I know I could not get away with just hone the block its way to far gone. I am eventually goin to boost the motor and sense I am going through the whole motor anyways while I am looking for the new head I wanna go ahead and bore the block I should be able to get away with 70mm. Just want to get all the machine work done at one time crank balanced and everything u know.
If you can get away with just honing the cylinder,,, That's exactly what I'd do... :cool: You aren't getting didly squat increase in displacement with a .020 increase in bore....
