Which AEM short ram intake will fit EG with GSR?
Which AEM short ram intake will fit EG with GSR swap with skunk2 pro series intake manifold? I know the GSR AEM short ram will fit but will it clear the hood .Although the LS AEM short ram fit also, will i pass smog due to having the different part made for different engine? Thanks in advance
From: Pensacola, FL and every Court House in Louisiana
You can use a ls sri but I would recommend a stock ITR box and intake tube. It is a 3" rubber tube with cone style filter and will work better than any metal sri with all the heat under the hood. I got mine $75 shipped from HMO. I have used Sri, cai, and a wrapped cai. The ITR def was an improvement on the butt dyno. My gsr with s2 pro IM, ITR box, and tri y header made 170 whp 123 wtq on a dc5000.
As far as emissions, I can't help you there but I would assume it wouldn't make a difference between ls sri and a gsr sri.
dwnthehatch
Sep 24, 2003 05:39 PM
