Mid-Atlantic (Sales) VA, DC, and MD
H22 and 90-93 Accord Parts
Old Apr 1, 2014 | 11:37 AM
kamAccord's Avatar
Default H22 and 90-93 Accord Parts
To view pictures of items for sale click on the various links below for each item.
D.C. Area
http://washingtondc.craigslist.org/d...391946662.html
NEW! 1990 -- 1993 Honda Accord Rear Brake Kit (Slotted Brake Rotors, Pads, SS Lines)
Rear Slotted Rotors; Rear Ceramic Brake Pads; Stainless Steel Braided Lines (Front and Rear)
90-93 Honda Accord Slotted Brake Rotors ZRC Coating L/R Rear
Slotted Brake Rotors vent gasses allowing the rotor and pads to stay in contact. The series of slots also wipe dust away from the pads and improve bite. Wet weather braking is also improved by preventing hydroplaning between the pad and rotor. SP Performance Slotted Rotors provide a bolt-on, hassle free way to greatly improve your vehicles stopping performance without expensive modifications.
Directional Mini 1/2 Slot:
Helps balance and stabilize friction level, optimizes brake pad contact and gives the rotors a very unique look.
Corrosion Resistant Finish:
Corrosion resistant finishes give a stunning clean look behind your wheels while preventing rust, corrosion and oxidation.
• The ZRC coating provides long-lasting protection against corrosion in the most hostile salt-water environments. After being applied, ZRC provides the highest level of galvanic protection. The film of ZRC is conductive. After the coating heats up during use, it bonds permanently to the metal surface. It will not allow the metal to corrode, even when the surface is scratched.
Drectional Angled Slots:
The Slots help increase brake pad bite, improve air circulation and Cooling. The slots also reduce brake fade and stop brake hydroplaning in bad weather greatly improving braking efficiency and reducing Stopping Distances.
Quality:
The rotors are made using the finest quality castings that exceed OEM specifications. Designed with the use of CAD software and produced on CNC machines insures the highest quality and consistent performance.
Features:
• The best in quality, performance, reliability and appearance.
• Hassle free, bolt-on performance - No need for any modifications.
• The benefits of Drilling and Slotting in one great package.
• Increased Brake Pad Bite - Greatly Reduced Stopping Distances.
• Vents gases and eliminates Brake Fade
• Maximized air circulation for best cooling.
• Corrosion Resistant Coating for long-lasting protection against rust.
• Improved wet weather stopping.
• Most cost effective way of improving your vehicles braking performance.
• Life Time Warranty - Guaranteed not to crack for the life of the rotors.
• Runs cool but looks hot behind your wheels.
Rotors are sold in Front or Rear Sets.
Brake Hose Kit
G-STOP SS Braided Brake Line Kit
G-STOP SS Braided Brake Line Kit; Incl. 2 Front Lines/2 Rear Lines/Adapters/Banjo Bolts/Washers/Line Locators;
FEATURES:
• Reduces Stopping Distance
• Terrific Performance Enhancement And Safety Improvement
• Conform To All Federal Requirements
• D.O.T. Compliant
• 9-Point Quality Assurance Testing Process
• More Consistent Pedal Response Under Heavy Braking
• Reduced Pedal Chatter When Use With ABS Systems
• Engineered high grade composite materials for superior braking and extended life
• Chamfered and slotted to prevent heat expansion cracks and to further reduce brake noise
• Strong resistance to fade under load and totally resistant to rotor vibration
• Enhanced friction for superior stopping, comfort, performance and low-dust for cleaner wheels
• New standard for quiet, reliable braking that last longer and provide superior stopping
• Manufactured to meet or exceed expectations for performance and fit
Prime Choice Brake Pads feature the advanced Premium Shim noise reducing rubber core brake shim technology that promotes silent braking. The result is quieter performance, superior stopping power and longer pad life -- the new standard in replacement brake components!
For serious inquiries only please text me on (202)674-3488. Be sure to check my other ads here on craigslist.
http://washingtondc.craigslist.org/d...391948112.html
1990-1997 New Megan Racing Front & Rear Strut Bar Kit - $89 (Washington, DC)
image 1image 2image 3image 4image 5
New Megan Racing Front & Rear Upper Stuct Tower Brace Bar + Rear Lower Arm Tie Bar 3pcs Combo
for
 Honda 1990 1991 1992 1993 1994 1995 1996 1997 Accord ALL Models
Part Number (SKU#): MR-3PSB-HA1001-RED
Description
• Item Condition: Brand New
• Make: Megan Racing, 100% authentic Megan Racing products
• This Combo Includes:
1. One Front Upper Strut Tower Brace Bar
2. One Rear Upper Strut Tower Brace Bar
3. One Rear Lower Arm Brace Tie Bar
• Color: Red
• Improve handling and stability
• CNC machined 6061 billet aluminum, very strong and last very long
• Special unique style
• 1.75" width with 0.75" thick bar
http://washingtondc.craigslist.org/d...391989331.html
Used Wings West Thruster Rear Wing w/Light for 1990-1993 Honda Accord - $30 (DC)
Used Wings West Thruster Rear Wing with LED Brake Light for 1990-1993 Honda Accord.
Local pickup only
http://washingtondc.craigslist.org/d...391950620.html
1990-1997 Honda Accord Ingalls Engineering Suspension Ball Joint Front - $89 (Washington, DC)
New! Ingalls Engineering Suspension Upper Ball Joint Front 1990-1997 Honda Accord
Product Description (# 35595 )
Ingalls Engineering Suspension Ball Joint Front Upper
Replace you old or worn balljoints with Ingalls Replacement Balljoints.
Manufactured to the same high quality standards of all Ingalls products Ingalls Replacement Balljoints will fit a perform to your expectations.
Adjustment range of +1.5° to +3°
http://washingtondc.craigslist.org/d...391949479.html
90-93 Honda Accord OEM Rear Left & Right sides, trailing arm, knuckle, and spindle - $325 (Washington DC)
image 1image 2image 3image 4image 5image 6image 7image 8image 9
90-93 Honda Accord OEM Rear Left & Right sides trailing arm knuckle spindle disc brake Ex
This is a rear right & left sides knuckle and trailing arm w/ABS wiring. SHOULD fit 90-93 Honda Accord with rear disc brakes
http://washingtondc.craigslist.org/d...396442033.html
MSD Digital-6 Plus Part #6520 - $250 (DC, MD, VA)
New MSD has combined race-winning experience with leading-edge technology to offer these incredible Digital-6 Plus ignitions. The 15 MHz micro-controller can analyze up to 15,000,000 critical instructions per second! That's over three times faster than comparable ignitions. Every spark is packed with 135 millijoules of spark energy and 535 V of power. Built-in features on the MSD Digital-6 Plus ignition include two rotary switch adjustable rev limiters, a single-stage timing retard, a start-up timing retard, an LED fault display, EMI protection, and much more! You get complete combustion for greater power, quicker throttle response, smoother idling, and quicker starts. You always get more power with less current draw.
Brand MSD Ignition
Manufacturer's Part Number 6520
Part Type Ignition Boxes
Product Line MSD Digital-6 Plus CD Ignitions
UPC 085132065202
Ignition Box Output Capacitive discharge
Circuitry Digital
Rev Limiter Yes
Timing Retard One-stage
Data Acquisition No
CD Voltage Output to Coil 535 V
Current Draw 7.4 amps at 10,000 rpm
Spark Output (millijoules) 135 Millijoules
Minimum Operating Voltage 7 V
Maximum Operating Voltage 18 V
Length (in) 8.500 in.
Height (in) 2.250 in.
Width (in) 4.500 in.
Ignition Box Color Red
Coil Included No
CARB EO Number D-40-31 (pdf)
To see a list of qualifying vehicles, enter CARB EO Number D-40-31
Quantity Sold individually.
Notes Works with both even and odd-fire V6.
Local pickup only. $20 additional for shipping in the Continental U.S. For serious inquiries only please text me on (202)674-3488. Be sure to check my other ads here on craigslist.
http://washingtondc.craigslist.org/d...391951670.html
MSD 8253 "Blaster HVC II" Ignition coil - $125 (D.C. Metro area)
image 1image 2
more ads by this user
Brand New MSD 8253 "Blaster HVC II" Ignition coil.
The "Blaster HVC II" ignition coil from MSD is designed to be used with their series 6 and SCI ignition controls. It is built entirely in-house at MSD and uses an iron U core design with a segmented bobbin for improved voltage distribution. This produces the most current possible with tremendous voltage and a rapid rise time. The solid brass primary terminals are spaced far apart and the secondary tower is protected to ensure good spark isolation. An epoxy compound protects the internal components from vibration and the entire unit sits on sturdy vibration resistant mounts.
Primary resistance, .16 ohms.
Secondary resistance, 630 ohms.
Maximum voltage, 44,000 volts.
Features
Designed for high rpm, long duration applications using MSD 6 Series Ignitions
New U-core winding design produces more voltage and current
100:1 turns ratio and lower primary resistance produce high voltage output
Windings are encased in fracture resistant compound for vibration resistance
Dupont Rynite housing with isolated tower and brass primary terminals
Supplied with rubber shock mounts
No CARB Exemption Order Number
Old Apr 1, 2014 | 08:42 PM
kamAccord's Avatar
Default Re: H22 and 90-93 Accord Parts
BUMP
Old Apr 4, 2014 | 01:44 PM
kamAccord's Avatar
Bump
Northernlightz
Jan 30, 2017 05:47 PM
stevescivic
31
Jul 17, 2011 10:48 PM
ptamarin
Mar 4, 2010 01:51 PM
Donboss
Nov 10, 2007 10:25 AM
BuyBrakesdotcom
100
Nov 9, 2005 11:16 AM
