2001 honda accord slight clicking
Old Apr 1, 2014 | 07:25 AM
thekid2390's Avatar
Default 2001 honda accord slight clicking
2001 honda accord with f23a4 it has a slight click no check engine lights but the sounds get louder has you hit the gas. I was told it can be one of two things 1.The oil pump is going out or 2.The valve lifters are dirty. Of course i;m thinking about doing the one the cost the least 1st so they said to get some additives and put them in the engine and see if that helps. What do the honda gurus have to say? should i just get a valve adjustment. I haven't done anything to it yet. Any advice will help. its my wife's DD.
Old Apr 2, 2014 | 11:17 AM
kvnwhite75's Avatar
Default Re: 2001 honda accord slight clicking
I don't think your car has hydraulic lifters, but you still may have noisy valves. Its very hard to narrow down odd noises, HFreight has those mechanic's stethoscopes for very cheap. It might help you out a bit. Since I'm no mechanic, and have heard the good and bad regarding additives I won't comment on them.
Old Apr 14, 2014 | 08:33 AM
thekid2390's Avatar
I got the valves adjusted and the car is still making the noise the people at home said the clicking is coming form the bottom.... And week later now it's has a start up delay... I have to Crank it's twice when it's cold to turn on
Old Apr 14, 2014 | 02:35 PM
holmesnmanny's Avatar
excessive noise could be a leaking exhaust manifold gasket .. u could seafoam and look for white smoke coming out at the leak
Slmahan
Sep 5, 2015 12:16 PM
Hayat Solangi
Aug 25, 2014 10:03 AM
necoris
Mar 31, 2004 08:20 AM
