Suspension & Brakes Theory, alignment, spring rates....
ITR master brake cilinder on EK4
Old Mar 31, 2014 | 09:05 AM
Goosse's Avatar
Default ITR master brake cilinder on EK4
I upgraded my EK4 262mm VTi brakes to a 282mm front setup from an ITR. I also wanted to upgrade the master brake cilinder. I now have an 15/16 VTi MBC and tried to fit a 1" ITR one. I noticed the following problem. When removing them, I would expect them to be the same.
But the EK4 one seems to have a guidence pin/pushrod on the MBC, which the ITR one doesn't have. I can bolt everything together, but it seems the rod coming out of the booster or my EK4 is to short for the ITR one. I measure a difference of +/-10mm. Can someone please shed some light why this is? Can I bolt the ITR one to my EK4 booster? I prefer not to remove the booster if it's not needed.
thanks
EK4
ITR
Matt_EH3
Suspension & Brakes
Oct 25, 2016 08:31 AM
Sassafrass
Jul 7, 2005 12:23 PM
jDMJeRk
Apr 29, 2004 04:42 PM
