Suspension & Brakes Theory, alignment, spring rates....
Add adjustable sleeves to coilovers?
Old Mar 31, 2014 | 07:05 AM
RiceBurnerRebel's Avatar
Default Add adjustable sleeves to coilovers?
I have a set of NuSpeed Race springs on Tokico shocks. I like the ride, because it is primarily for Auto-X, however it is WAYY too low.
Question:
Can i buy these cheap adjustable coilovers, and use the adjustable sleeves with my NuSpeed springs? Essentially making my NuSpeeds into adjustable coilovers...
http://hondamarketplace.com/showthread.php?t=3197395
Thanks,
Fred
Old Mar 31, 2014 | 10:01 AM
doood's Avatar
been there done that
Default Re: Add adjustable sleeves to coilovers?
No. You would use the springs that came with the sleeves.
Old Mar 31, 2014 | 09:00 PM
redlinetuning's Avatar
no. if I remember correctly the Neuspeed springs do not have a flat bottom to rest properly on the adjustable perches.
If you like the springs you have now you could probably get the Koni yellow struts with the perch cups. Then you could adjust the desired height.
Old Apr 1, 2014 | 10:51 AM
TunerN00b's Avatar
All that the OP really needs are spring spacers. Cheapest way to raise the car, keeps the existing spring rates, no adjustments to screw up.
Old Apr 4, 2014 | 07:00 AM
cetcivic's Avatar
no one wants to hear the truth
Im sure GC makes coil over sleeves for tokico
bigpunn421
Suspension & Brakes
11
Jan 22, 2012 11:03 AM
DC2_2
Oct 14, 2006 06:28 AM
VeilSide_Mas
Suspension & Brakes
Mar 27, 2006 10:00 AM
sohcvtec97
Feb 25, 2005 07:07 AM
paulyman
Mar 2, 2002 04:43 PM
