For those with A/T
Just something I that I came across, thought it might interest someone.
http://www.takakaira.com/asp/template.asp?id=719&cat=2
After long and hard research into automatics in general, The single most thing that MUST be changed related to the transmission in order for it to handle real POWER and TORQUE
is NOT: Torque converter, clutch plates, This electric gismo...
it IS: The valve body itself, higher tension springs, and different routing of fluid. Reason being you have to create alot more pressure in the tranny, ie more CLAMPING force, otherwise even if you upgraded say clutch pads, without the force to apply them to shift you will just slip.
Likewise with a BEAST tranny, with indestructable gears lets say, if your clutch sucks... well you will slip and all those interior things you did really mean nothing.
