b16a2 w/ ctr ecu?
Old Mar 29, 2014 | 10:53 AM
SELF MADE's Avatar
Default b16a2 w/ ctr ecu?
I have a 97 civic coupe dx (was auto) I recently converted to manual and swapped in a b16a2 swap from a 2000 si. I used the original harness did the 3 wire to 2 wire iacv conversion and also the 3 wire to 2 wire cfk plug. Everything is plugged in im currently borrowing a obd2a p72 ecu (gsr) which it runs fine with but runs a bit rich. I recently bought a obd2a pct (ctr) ecu but idles very low almost ready to die. Acceleration is fine but when I let off throttle the engine almost wants to shut off..
My question is: is this jdm pct ecu compatible with a my us b16a2?*
Thanks in advance!*
Old Mar 29, 2014 | 05:53 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: b16a2 w/ ctr ecu?
you need a USDM P30 OBD2A.
Old Mar 29, 2014 | 08:47 PM
eghatch9295's Avatar
Stancetard Hate Monger
both ecu's are very very wrong. dual iab's on gsr, fuel mapping and a dozen other issues.
Old Mar 29, 2014 | 09:42 PM
SELF MADE's Avatar
Well I know the p72 is wrong I borrowed it just to see if there was something wrong with the ctr ecu or the motor.. I havent had any luck finding a obd2a p30
Old Mar 29, 2014 | 09:58 PM
the ctr ecu is nowhere near right, either. convert to obd2b and use the em1 ecu.
Old Mar 29, 2014 | 10:02 PM
SELF MADE's Avatar
Obd2a to obd2b jumper harness?
Old Mar 30, 2014 | 04:42 AM
doctorake's Avatar
Community Builder
Em1 p2t ecu will through codes for ftp sensor since the hatches do not have one.
r81-DC2
May 29, 2007 04:54 PM
CSHornet60
Mar 5, 2007 09:52 AM
jdmcivicsi7
Apr 2, 2006 10:43 PM
Ex-ITR5874
Jul 20, 2002 05:15 PM
