Honda CR-V & Element 2WD & 4WD Element & CR-V
integra trans in crv???
Old Mar 29, 2014 | 10:27 AM
roro1's Avatar
Default integra trans in crv???
I have a 97 awd automatic crv,the trans went out and i have a good 94 automatic integra transmission in the garage,can i use the integra trans and just not put a drive shaft back in for the rear wheels?
Old Mar 30, 2014 | 03:36 AM
PhilStubbs's Avatar
Default Re: integra trans in crv???
It probably won't work well if it does. I'm sure the gear ratios are different, making the shift points different. The crv ecu will be confused
Old Mar 30, 2014 | 09:25 PM
ARMED's Avatar
try it! might get a code for tranny mis shift
Old Mar 31, 2014 | 05:20 AM
tony_2018's Avatar
Fish Twig
You'll get a code for linear solenoid, which the 94 auto tranny doesn't have. You can fool it by plugging it in but you'll need to swap out your throttle body to accomodate the tranny throttle cable. Just some technical theories here.
Old May 7, 2024 | 09:52 AM
Japinales2004's Avatar
has the swap been done ?
Old May 7, 2024 | 08:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
TEN YEARS LATER...
Old May 8, 2024 | 06:21 AM
Ryanthegreat1's Avatar
billy barker
Apr 6, 2013 07:33 PM
brainglow
Sep 22, 2007 08:57 PM
rasinhell
Jan 27, 2006 09:45 AM
Vic Nyce
Oct 4, 2005 07:56 AM
