Sleeved Longblock, PeakBoost Topmount, GT3582R, Wastegate, Injectors, Intercooler....
Parting out our project drag car. Open to reasonable trades.
Located in Carson, California 90746
Call or text
424 731 2162 JR
310 961 7175 Rod
see link for more parts http://hondamarketplace.com/showthread.php?t=3200872
*$3500(willing to part head & block)- LONGBLOCK: Motor has 0 miles since rebuild. Has new gaskets, seals, rings, OEM water pump, OEM timing belt, etc.
1999 GSR Block (VIN # upon request)
-AEBS T-Sleeves Solid Deck w/ Copper O-Rings (Done by AEBS)
-JE 84mm Pistons w/ Ceramic Coated Tops Nitrile Coated Skirts Straight Wall
-JE Pro Seal Rings (NEW)
-Pauter Chromoly Rods (Standard GSR Length) (ARP 2000 Hardware)
-AEBS Main studs
-ARP Head studs
-Stock GSR crank w. micro polished journals & cryo treatment (Standard clearances)
-AZ Billet Aluminum Race Girdle for Main Caps
-Tapped oil pan
1997 USDM ITR B18C5 Head
-Cometic Head gasket
-5 Angle Valve Job
-Deshrouded Valve Ports
-Mild Port/Polish
-Supertech Valves (.05 oversized): Nitride Coated Intake Valves, Iconel Exhaust Valves
-Buddyclub Dual Springs
-KMS Titanium Retainers
-KMS Valve Seals
-Stock ITR Cams
-Skunk2 Cam Gears
-AEBS Billet Aluminum Cam Seal
-New A2 S/S Socket set screws and serrated flange nuts for Exhaust/Turbo Manifold
*$1000- PeakBoost T3 Topmount Manifold w/ 44mm flange v-band, coated w/ 3” PeakBoost Downpipe
*$800- Garrett GT3582R Turbo w/ .63 AR Exhaust Housing
*$60- Brand New Universal Intercooler 31x12x3” w/ 3” inlet and outlet
*$250- Brand new Synapse Synchronic Universal 44mm V-band flange with 50mm valve Wastegate in Black w/ Flanges and Clamps
*$150-1000cc MSD Injectors (Resistor Box required)
Call or text
424 731 2162 JR
310 961 7175 Rod
-AEBS Main studs
-ARP Head studs
-Tapped oil pan
-5 Angle Valve Job
-Mild Port/Polish
-KMS Valve Seals
-Stock ITR Cams
-Skunk2 Cam Gears
GSR_ITR_BOIB
Jan 14, 2019 01:42 PM
slofton77
24
Apr 19, 2011 03:50 PM
