96 EX D16Y8 oil leak
Old Mar 28, 2014 | 05:37 PM
Trafficlightguy's Avatar
Icon2 96 EX D16Y8 oil leak
Installed new oil pump with new o ring and honda bond torqued to 9 ft lbs. it only drips while the car is running, I drips from the front corner of the oil pan closet to the firewall
I cleaned it off and it seems to be leaking from that Allen key type recessed bolt that sticks out from the timing belt cover
Any thoughts
Old Mar 28, 2014 | 07:02 PM
lightravels's Avatar
Default Re: 96 EX D16Y8 oil leak
Sorry to hear that. From the sounds of it you may have torn of folded a lip on the crankshaft oil seal. When you replaced the oil pump did it come with the crank seal already installed? If so, did you lube that seal or the crankshaft with a little oil before installation?
Old Mar 29, 2014 | 06:20 AM
Former User's Avatar
Post pictures of the leak area.
Old Mar 29, 2014 | 06:47 AM
tony_2018's Avatar
Fish Twig
Is this a new or used pump? oem or pepboys/autozone/o'reily/advance?
Old Mar 29, 2014 | 08:06 AM
It's a new mitzo pump with the oil pump mod less the shim
somick
Aug 15, 2017 08:14 AM
puckman_j
Mar 3, 2013 05:02 PM
rush2112
Jan 17, 2008 03:55 PM
alotawatts
Jan 13, 2005 04:32 AM
Boostless97Lude
Jan 8, 2003 09:53 AM
