NEED HELP D16Z6 into 91 CRX Si WONT START
Old Mar 27, 2014 | 10:07 PM
cannouu's Avatar
Default NEED HELP D16Z6 into 91 CRX Si WONT START
I just installed a rebuilt D16Z6 swap into my 91 Honda CRX Si. Car was already running perfectly on it's original engine and is stock MPFI. I did all the necessary OBD0 to OBD1 conversions, every sensor is connected and wired correctly. Engine turns over and has no check engine lights. Has spark, has compression, timing is right, and it seems to not be getting fuel. Car starts when I spray starter fluid in the throttle body. Fuel pump primes upon ignition just as it is supposed to, injectors switched from a working engine, inejctors been tested for resistance, voltage, and continuity to the ECU. What am I missing? Anyone have any suggestions? Thanks in advanced!
Old Mar 30, 2014 | 05:32 PM
video_voide's Avatar
Default Re: NEED HELP D16Z6 into 91 CRX Si WONT START
Maybe the throttle cable needs adjusting. Perhaps the throttle plate is closed too much. Turn the key to position 2, let fuel pump prime, turn key the rest of the way while slightly depressing gas peddle, slightly.
cannouu
Engine Management and Tuning
Mar 31, 2014 11:58 AM
Eurocrx1991
Nov 14, 2012 05:13 AM
TehTaylor
26
Jan 30, 2012 11:49 AM
thesquadz909
Jun 1, 2007 07:55 PM
Toquick4ya
May 11, 2007 04:42 PM
