92 si hatch electrical problems after unplugging battery and revving engine
Old Mar 26, 2014 | 05:03 PM
Michaelfinn95's Avatar
Default 92 si hatch electrical problems after unplugging battery and revving engine
Story goes, I unplugged the negative battery terminal and revved the engine and it fried a few fuses and i replaced them and the main relay...
now i have only a batter light and SRS light on the dash with the ignition in the on position, not beeps no engine light no e-brake light etc...
what could posibly be going on???
Old Mar 26, 2014 | 05:20 PM
Former User's Avatar
Default Re: HELP! 92 EG si hatch
Check all the fuses. Hope or pray you did not fry every fragile electrical circuit in your car.
Old Mar 26, 2014 | 05:25 PM
i checked all fuses.... so that means... new ecu
Old Mar 26, 2014 | 05:32 PM
I have a spare ECU and will try it tomorrow.
So more detail on my problem, I went thru the whole process as stated before, but after i replaced the main relay I turned the key on and all the lights came on as they should other than the engine light. The engine light stayed on. so i replaced a few bad fuses and turned the key on, this is when i had NO dash lights othe than the battery and SRS lights... Turned the key and car would turn over but not start.... I dont want to put the new ECU in if it is just going to fry as the first one did...
stevenjr
Feb 3, 2013 03:29 PM
[JDM]noob
Dec 7, 2009 07:20 AM
iKhmaiFoSho
Dec 15, 2006 02:20 PM
jondancer
Apr 24, 2004 09:39 AM
