Transmission/CEL problem. HELP.
Just got my transmission replaced and everything worked fine for a few hours then speedo went out CEL turned on and a little after that my idle went up. Anybody know what the problem could be? Easily fixable? Thanks guys!
You have two different problems. The car won't throw out a CEL if the transmission has a problem because you have no wiring connected to the wiring harness and the speed sensor goes directly to the cluster..
Yes, should be an easy fix. The VSS/ Speedo cable probably popped loose from the transmission. Happened to me when I replaced my 4 speed with a 5 speed. When you put the cable back in, make sure you turn it when putting it in. I didn't do that and it popped out and the speedo stopped working and got a cel code. If it is already in tightly, check to see if it is connected to the cluster securely.
