is my CEL not working properly?
Old Mar 25, 2014 | 10:06 PM
titan74's Avatar
Default is my CEL not working properly?
Hi, I tried to test my CEL by intentionally disconnecting the map sensor. When I turn the ignition on, the CEL went on, and when I started the engine, it went off, like normal operation.
Here is my vehicle's background:
1997 Accord LX
Engine swap with H23
Chipped P28 ECU
I am expecting that the CEL will stay on. What could be the problem?
I am interested to make sure the CEL is indicating an error because I am working to solve a "no VTEC engagement", which I read that first thing is to make sure there is no CEL. Thanks.
Old Mar 25, 2014 | 10:37 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: is my CEL not working properly?
Low oil or stuck VTEC oil pressure switch will not set a code. It will simply not allow VTEC engagement.
When you pulled the MAP sensor wire, did you try to rev the engine? If so, what happened?
Boots
Jan 5, 2007 09:35 PM
PokeyD16Z
Jul 5, 2004 07:47 AM
SearchBeforeUPost!
Mar 31, 2004 06:54 PM
SearchBeforeUPost!
Mar 31, 2004 05:39 PM
SearchBeforeUPost!
Mar 31, 2004 05:07 PM
