need help h22A4
Use punctuations to form sentences, so that others may be able to understand what you want. Grammar goes a long way, I cant understand any of what you tried to communicate.
I can say random words too; so vtec much fast zoom you skunk2 ARP head studs.
Ok guys, asking for someone to make complete sentences is good, but just randomly being dicks about it is not so cool.
OP - there are many springs you can use, but they will be based more on the camshaft of choice than the valves in use. Personally I like to use the matched valvetrain, so I run Skunk2 springs with Skunk2 cams. Depending on the "stage" of cam, you should use either the Tuner or Pro springs. The Pro spring is actually the same as the B series springs, just using an adapter shim for the H head.
If he wants an intelligent response, he should put the effort into actually say something people can comprehend. Until then he should be happy to get any response. English better be his second language...
Have fun with this one
1990_integra_DA9
Jun 8, 2008 12:33 PM
