97 distributor rotor
Old Mar 25, 2014 | 11:35 AM
kidgrinder's Avatar
Default 97 distributor rotor
Having more trouble then imagined I cant get the distributor rotor off my 97 lx
I figured id have a little trouble getting it off so I hit it with a little electrical cleaner and put a little bit of di-electric greese inside as best I could and let it soak over night.
this morning I've destroyed everything off it but a little flange thats left, so I tried too use my rotary grinder and cut a little slit too put a screwdriver in and break it off but that hasnt been working either..
Whats the next step I know pb blaster isnt ideal and I dont want future problems but Im kind of stuck and need this car for transportation..
Thanks guys
Old Mar 25, 2014 | 12:44 PM
GhostAccord's Avatar
Default Re: 97 distributor rotor
Not 100% but I think the 97 rotor is held on by a small screw in the base of the rotor shaft collar. If you have the dust shield still installed you may have to rotate the engine in order to have it line up with the opening.
Old Mar 25, 2014 | 01:48 PM
holmesnmanny's Avatar
Ghost is correct. You can either rotate the engine counterclockwise or remove the distributor and turn the rotor with your hands to access the screw you need to remove to get the rotor off.
Old Mar 25, 2014 | 03:40 PM
kidgrinder's Avatar
I was aware of the screw and had already removed it.
It was literally just seized on there I ended up just using my dremmel too cut slits in it and then chizzle it too bare metal and then pull it off with a wrench for future reference.. thanks guys
Old Mar 25, 2014 | 06:35 PM
putting a pair of vice grips on it and hitting the vice grips with a hammer after putting the distributor in a vice wud prolly do the trick
Franzwa
Honda CR-V & Element
Aug 6, 2018 12:06 AM
William1991b
Nov 2, 2011 07:29 AM
cticknor666
Jun 6, 2010 07:47 PM
CTL
Jul 12, 2002 06:28 PM
