starting problem with my 1998 honda civic lx
Old Mar 25, 2014 | 04:38 AM
djkrucifixx's Avatar
Default starting problem with my 1998 honda civic lx
My 1998 honda civic will not start I repalced spark pulgs and wires took aprt the disruptor and cleaned all the contacts it gets spark replace starter and main relay it gets fuel because after a few trys of turning it over all u smell is fuel I need help
Old Mar 25, 2014 | 01:18 PM
994door's Avatar
Default Re: starting problem with my 1998 honda civic lx
Search first
FAQs - https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
no start Diagnosis 101 - https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Old Mar 25, 2014 | 01:26 PM
Former User's Avatar
Is spark bright white at all 4 plugs?
Have you checked the mechanical timing and compression tested the cylinders?
Old Mar 26, 2014 | 01:05 AM
Spars are all bright white even had a fireball come out of one of the tubes because a spark plug was to close
Old Mar 26, 2014 | 03:59 PM
new update i unplug the injectors and it starts for a sec
Old Mar 26, 2014 | 04:15 PM
Try starting fluid.
Old Mar 31, 2014 | 12:48 AM
Update fixed timing and it runs but no power found out fuel line is leaking from rust build up will update if it works
ScareCrower
Jul 8, 2015 05:49 AM
GarageNut
Jul 1, 2012 10:16 AM
Riftycent
Apr 4, 2012 06:25 AM
rxbahamut
Classic Hondas
Apr 9, 2011 09:11 AM
sweetmelissa
Jun 9, 2009 12:50 PM
