H23 trans to an F23 block
First off will the h23 tranny work in the F23 block, I'm in the middle of the G23 build on my 01 and getting off the auto trans is next on my list. I have a perspective tranny for a steal comes with shift linkage too.
So if it does fit is there anything other than the clutch pedal that I'm overlooking for the swap list?
If the h23 doesn't fit is there a model that does? I've heard b16/18's do but cannot find any proof.
Thank you all for you time, y'all helped me on my ls swap last time!
Clutch forks are the same,
Both= 22821-P0S-000 FORK, CLUTCH RELEASE
but the bearings carry different part numbers
Prelude= 22810-P21-003 BEARING, CLUTCH RELEASE (FUJIKOSHI)
Accord= 22810-PX5-J02 BEARING, CLUTCH RELEASE (KOYO SEIKO)
Since the fork is the same, and the clutches are interchangeable, I'm guessing h clutch+h throw out and f clutch+f throwout? Is look at majestic right now to compare pressure plate and clutch part #'s, but I'm at work. Appreciate it, Mike.
xxmastermindxx
Jul 26, 2006 07:53 AM
