98 Accord EX Starting Issue
Old Mar 24, 2014 | 01:34 PM
HammAccord's Avatar
Default 98 Accord EX Starting Issue
Hey there, I have a 98 accord 3 litre vtec that drive me to school this morning, then when I parked and turned it off, I lost all power. I then got a boost from a friend, no power until about 10 seconds then I could turn it over. I then drove home no problem, turned it off. Put the key back in and turned on my heat and all dash lights as normal and started over, figured nothing was wrong turned it off went inside. Couple hours later went to go to work and no power whatsoever.. Weird part is that my clock has power when nothing else does.. Only thing that will, until I turn the key past accessories, and if I press my brake pedal. Steering wheel and brake pedal lock and get tense after I lose power, so confused
Old Mar 24, 2014 | 02:56 PM
holmesnmanny's Avatar
check your battery connections .. a corroding battery will leak acid which could put a film arround battery posts causing connection loss
Old Mar 24, 2014 | 08:05 PM
accordturb96's Avatar
Default Re: 98 Accord EX Starting Issue
Exactly^ turn the key on and cautiously wiggle the battery connections. Should turn on
Umprusty62
Feb 7, 2018 05:31 PM
Sean-45
Oct 6, 2017 08:37 PM
dnguy47
May 8, 2010 05:53 PM
tobey98
Jul 9, 2007 07:00 PM
98Accord DOHC
Dec 25, 2006 06:14 PM
