civic was just running now wont start
Old Mar 24, 2014 | 01:03 PM
Preludekid55's Avatar
Default civic was just running now wont start
hi everyone, i was just driving my civic dx ls swap and it was driving fine when i got home i shut it off and decided to change my blinker bulb after i changed the blinker i went to turn it back on and it wouldn't start doesn't even turn over no click noise nothing the radio and lights work and i know its not the battery cause i tried jump starting it and got nothing.
Old Mar 24, 2014 | 02:53 PM
fcm's Avatar
fcm
Old Fart
Default Re: civic was just running now wont start
Hard to say without testing...
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/ 94
Old Mar 27, 2014 | 10:45 AM
daw128's Avatar
Had similar problem with grandson's 93 Civic. Changed main relay switch for him and problem solved.
Old Mar 27, 2014 | 11:44 AM
fcm's Avatar
fcm
Old Fart
The PGM-FI Main Relay has nothing to do with engine cranking. 94
Old Apr 2, 2014 | 01:07 PM
recent update....got a new battery and it started and ran fine. checked the alternator at local autozone and its fine. i drove it for about a week with no problems then again today it wouldnt start or crank.
Old Apr 2, 2014 | 10:24 PM
Runnerdown's Avatar
Did you check the starter circuit, right above the link is posted by fcm. Its a very simple thing to check and will isolate the problem to either the starter, or the portion of the circuit that includes the ign switch and clutch switch.
ReSpade
10
Mar 3, 2014 08:27 AM
oXeNo
Nov 18, 2011 01:04 PM
OneWickedef2
Mar 25, 2008 02:45 PM
junkyardRx
15
Apr 26, 2004 03:04 AM
Jolf
Aug 14, 2003 03:44 AM
