Sleeve and Tapping Help
Old Mar 24, 2014 | 08:48 AM
apaige58's Avatar
Default Sleeve and Tapping Help
Alright, I have a D16Z6 that has the bolt holes where the distributor is suppose to screw into stripped. I drilled them out but tapping to a larger bolt size will not allow me to fit the new bolts through the slots on my distributor. Also there is barely any room if at all to even get the tap handle to rotate, any tips or ideas would be great. I just want to get my distributor back on flush with no leaks but I still need the range of motion so I can set the timing of course.
Thank you
Old Mar 24, 2014 | 08:50 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Sleeve and Tapping Help
Heli coil or threadsert.
Old Mar 24, 2014 | 08:51 AM
Fliptard's Avatar
Just re-tap and use a dremel to open the slots in the dizzy for the bigger bolt to slide thru.
bamaland601's Avatar
if you drilled it out, then you have to drill out the slots on the dizzy bigger.
Old Mar 24, 2014 | 10:00 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
This is your best option and it lets you stick to stock bolt sizes.
Old Mar 24, 2014 | 10:16 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
safe sert.
Racing rice
May 30, 2007 05:45 AM
85civic
Aug 14, 2004 01:38 PM
85civic
Aug 14, 2004 12:27 PM
Accord15
Mar 22, 2004 11:42 AM
faultofhumanity
Sep 15, 2003 07:47 PM
