Type s swap in base rsx
Old Mar 23, 2014 | 06:13 PM
Will's_spot's Avatar
Default Type s swap in base rsx
So I picked up a smashed type s from nj the other day an I just took the car apart today. The car came with lost of goodies all around. That being said, I want to take the s swap an drop it in my rsx (tranny an all) I looked some stuff up an all ppl wore talking about was the ecu. I took the ecu from the type s so I should be good. I would like to know if there is anything else I should be looking out for before I start this project. I'm only putting the swap in the car all the other goodies are up for graves.
Old Mar 23, 2014 | 08:46 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Type s swap in base rsx
just taking the ECU does you no good, you need to swap everything like the keys, ignition and immobilizer. You will need an immobilizer bypass or kpro. I recommend kpro if you plan on modifying the car in the future. Either way you need to get around the immobilizer.
GoldieWang
K Series
Aug 3, 2014 09:59 PM
Accord k24a4
Nov 29, 2010 05:58 AM
tblango
Oct 3, 2005 08:23 PM
