if you had 4g's and a stock automatic del sol si with 102k miles... wwyd?
Old Oct 29, 2002 | 04:05 PM
95si's Avatar
Default if you had 4g's and a stock automatic del sol si with 102k miles... wwyd?
if you had 4g's and a stock automatic del sol si with 102k miles... what would you do?
Old Oct 29, 2002 | 04:11 PM
Spade's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (95si)
Honestly.
Sell the Del Sol for as much as I could and go put a down payment on a 2002 Pontiac Trans Am with a WS6 and a 6 speed tranny.
5.7L beast. with 315 RWHP stock.
EDIT: NOTE: A cam equivalent to the HKS 272 degree cams costs a total of 100 dollars shipped!!!!
[Modified by Spade, 5:12 PM 10/29/2002]
Old Oct 29, 2002 | 04:26 PM
RedHatch's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (Spade)
strip it...
get a rear engine h22...
that should cover it right?
Old Oct 29, 2002 | 04:31 PM
clm_Sol's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (RedHatch)
I'd either sell it and buy another Sol (or any other car - Trans Am does sound nice ) or do a 5-speed swap.
Old Oct 29, 2002 | 04:55 PM
95si's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (clm_Sol)
ok, what would you do, keeping the sol.
Old Oct 29, 2002 | 05:03 PM
Hyjnx's Avatar
Tranny Swap..then save for a turbo
Old Oct 29, 2002 | 05:15 PM
eg_nezay's Avatar
first off, do u still want to keep that car?
IMO I would
sell it and get more money + the 4Gs = hatchie with a swap, wheels and suspension
[Modified by eg_nezay, 2:17 AM 10/30/2002]
Old Oct 29, 2002 | 05:19 PM
Soundwave9900's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (eg_nezay)
put on a muffler tip with lights. and spend the 4000 on porno.
Old Oct 29, 2002 | 05:24 PM
SikofFalln's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (soundwave9900)
Keep the del sol as my daily drive and buy a used crotch rocket.
Old Oct 29, 2002 | 05:26 PM
DevinW's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (BseriesPWR)
"sell it and get more money + the 4Gs = hatchie with a swap, wheels and suspension "
Old Oct 29, 2002 | 05:35 PM
J T*'s Avatar
that's what I did(only I have a coupe). now I got a 10 sec honda that I only paid $4500 for. plus its alot more fun in the canyons
Old Oct 29, 2002 | 05:36 PM
clm_Sol's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (DevinW)
If you want speed (which I'm sure you do because stock civics are slow), I would swap in a 5-speed and go turbo. If you want to keep the automatic, you're limited on how big of a turbo set-up you do because automatics apparently don't hold *too* much power (not sure about a WHP #).
If you're more into show and not too fast, then bolt-ons (maybe nitrous, too), wheels and a set Teins would work as well.
Old Oct 29, 2002 | 05:42 PM
Kamin's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (J T)
b16+turbo.
Old Oct 29, 2002 | 06:15 PM
maskednegator's Avatar
Honestly.
Old Oct 29, 2002 | 07:46 PM
nwdave's Avatar
Default Re: if you had 4g's and a stock automatic del sol si with 102k miles... wwyd? (maskednegator)
Some points:
—The engine has too many miles on it to do anything drastic and still have it last.
—The tranny has the same problem.
With that said, I suggest buying a hatchcrap or 4th Gen Civic, and build that.
Or, if you want to do something hardcore, swap in a D16Z6 with a manual tranny and boost it with GReddy kit.
nateb22
38
May 2, 2009 05:34 PM
tallhamer88
19
Mar 11, 2009 08:55 AM
b18c5-EM1
Jan 30, 2005 07:06 AM
Slvr_CRX
Jul 14, 2004 08:48 PM
craps_shooter
Mar 7, 2002 04:33 PM
