Tranny problems
Old Mar 20, 2014 | 08:14 PM
GrantFuentes's Avatar
Default Tranny problems
I have a 99 civic hatch standard d16y7 1.6L. My tranny literally blew up on me. My first car, loved it, drove the hell out of it. For about a month before there was a grinding in the tranny. It wasn't the axles and a tech I work with that been in the trade 20 years said it def was not the clutch. He couldn't describe it other than that when the clutch disengaged the noise stopped. He's a racer too, he built a car that runs 5.6's at a 1/4 mile. I trust him. I didn't have the time or money to start ripping apart the tranny. I can't afford to put a new one in right now but it's bugging the hell out of me what it was. And let alone not knowing anybody with the same problem. The grinding was for about a month and then on the way to work going 100 km/h (60 mph) she just blew up.when I stopped there was tranny fluid all over the ground. Anybody else have an issue like this?
Old Mar 20, 2014 | 08:18 PM
crazyhouse2011's Avatar
Default Re: Tranny problems
Grinding is a main shaft bearing in the tranny, most likely the input shaft bearing. I don't know why that would cause you to blow your fluid though.
Old Mar 20, 2014 | 08:19 PM
Former User's Avatar
Disengaged (pedal down) would indicate a bad throw out bearing, but I bet the noise happened with the pedal up, which would indicate a bad transmission main bearing, such as the input shaft bearing.
Old Mar 21, 2014 | 12:21 AM
eghatch9295's Avatar
Stancetard Hate Monger
yep, may have blown up your differential. when the isb totally goes, it can wreak havoc inside a transmission. time for a new one.
Old Mar 24, 2014 | 03:07 AM
That def gets me closer to the answer. Still not sure why she blew up on me tho. Only way to tell would be to start ripping the tranny apart which I don't really want to do.
Old Mar 24, 2014 | 07:29 PM
My cv axle popped out and smashed a chunk of my tranny out too. That was what the big noise was
Old Mar 24, 2014 | 07:46 PM
NotARaCist's Avatar
I never narc'd on nobody!
That's not where your axle goes, that's the drain hole...
Old Mar 24, 2014 | 08:11 PM
lol
Old Mar 24, 2014 | 11:09 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
That is not the drain hole, that looks like the snap ring access port to separate the case. And is where the back side counter shaft bearings resides. I can see the snap ring/c-clip in the photo and the bearing it clips to. I also see there are no ball bearings in that race on the counter shaft, so the shaft at 60 mph started slamming all over that part of the case inside the race.
It blows up because the bearings seize up and throws a ball bearing or two and the cage around in the tranny. Then the shaft no longer rotates in a confined spin, instead now it can slam itself around in wide circles putting all kinds of stresses on the gears and synchros and the remaining bearings and the case.
Usually when bearings blow, the tranny isn't worth salvaging. It's typically more cost effective to get a remanufactured tranny and drop it in. For this you will need a case half, who knows what other damage is done to the internals and of course several bearings.
The grinding you were hearing was the clue that your bearings in the tranny were very bad and desperately needing changing. Now you see why you don't ignore grinding in a tranny. The end result is catastrophic.
Old Mar 25, 2014 | 04:10 AM
BryanM.'s Avatar
Resident Gearhead
Axle probably jumped out and bashed the case and that plug fell out, puking oil all over the place.
tsgeekz
Transmission & Drivetrain
Dec 19, 2008 01:16 PM
mikes 95 integra
Feb 25, 2008 06:36 AM
-tc-
Oct 25, 2005 07:44 AM
4drferio
Apr 29, 2004 10:59 AM
