1991 Prelude main relay fuel pump
Can I use a 1991 civic main relay to replace my prelude relay? They look identical, I have run the tests on my relay and the coil will not operate for the fuel pump. It appears that the relay is a rz-0088 for the civic and the prelude is rz-0081, anyone know? The civic is half the price of the prelude, plus I can't seem to find a prelude relay available. Thanks in advance
Im sure as with fuses as long as its the same amps/volts/ohms rating and fits there should be no problem.
If you use the wrong size you can melt wires.
pre93lude
Jun 22, 2008 12:12 PM
