4 wire o2 sensor wiring
I've done my research and keep coming up with conflicting information. Please clarify. The images I am using are not my own, but harvested from online.
Image 1 shows the engine harness o2 connector.
green/white = ground
white = signal
orng/blk = heater
yell/blk = 12v
Image 2 depicts the wire side or back of the o2 sensor connector. This image does not coincide with the above image.
I am inclined to go with the first image. I am using a Rywire engine harness. And wiring a Denso o2 sensor.
white = signal
orng/blk = heater
yell/blk = 12v
I beg to differ.
When joining these two clips, the drawn clip would be rotated 180 degrees, where as the clip in the photo would be rotated to the right 90 degrees.
See what I mean?
See what I mean?
Image 1 is of the engine harness.
Image 2 (drawn) is the O2 sensor.
When you rotate the drawn image 90 degrees CCW (to the left) so that the clips engage, then each wire matches up correctly when you plug them together.
I see nothing wrong here.
When I did my wiring, I ignored colors and just made sure it all went to the right pin. I used junkyard connectors and ignored their original purpose.
That's just it, the drawn image would have to be rotated Clock Wise to the right 90 degrees in order to engage clips.
When I wire up my o2 sensor I'm just going to mirror the engine harness pictured.
95gainfla
13
May 7, 2007 09:01 AM
trooper0641
Apr 28, 2004 08:31 AM
