Did our OBD0 Distributors come with an Ignition Coil Spring?
Old Mar 20, 2014 | 03:03 AM
hatcht9x's Avatar
Default Did our OBD0 Distributors come with an Ignition Coil Spring?
I'm in the process of rebuilding the TD-02u distributor off my 88 CRX HF due to a slight misfire. During disassembly, I noticed there was no spring in the ignition coil or the corresponding contact on the cap. My BOSCH replacement coil didn't come with one, and the online catalogues don't show that they are included with the OBD0 coils; but are included with the OBD1 coils. Were these not utilized on our cars?
I have been searching for a while, but I can't come up with a definitive answer.
Thanks in advance.
Old Mar 20, 2014 | 12:50 PM
SpeedOFsmell's Avatar
Default Re: Did our OBD0 Distributors come with an Ignition Coil Spring?
My 1990 Si's stock distributor had a spring behind the contact built into the cap, if that's what you mean.
Old Mar 20, 2014 | 12:51 PM
I bought a cap for a 1991 integra assuming it would fit my b20 swap, then realized when i went to install it that my car was running the stock civic distributor, which has a spring in the cap contact, and the integra cap did not. also, the long groove in the cap is slightly tilted on an integra cap and straight down the middle on a civic dizzy.
Old Mar 20, 2014 | 05:34 PM
hatcht9x's Avatar
Thanks for the info Speed. When my cap came in today I discovered the spring loaded set up you're talking about. Thanks again
dave n
Nov 20, 2013 10:41 AM
IndySporty
Jul 27, 2010 01:19 AM
shaylude
Jun 17, 2010 08:19 AM
rice a roni
Dec 14, 2006 07:31 AM
menappi
Jun 26, 2006 05:37 PM
