Need help with a open in my a/c electrical wiring.
Old Mar 19, 2014 | 11:59 PM
dperry's Avatar
Post Need help with a open in my a/c electrical wiring.
My a/c compressor is not running. My car is a 92 Prelude Si automatic. I'm using a 92-96 pdf service manual and a digital multimeter to troubleshoot this a/c issue. I have just troubleshot down to the very bottom of thumbnail page 1,051, which is page 22-17.
The service manual tells me to "Measure voltage between the YELLOW/BLACK2> and BLACK/YELLOW2> wire terminal with the negative probe grounded to the body." I am not getting a battery voltage reading. The repair manual tells me to "Repair open in the YELLOW/BLACK2 <BLACK/YELLOW2> wire between the under-dash fuse/relay box and compressor clutch relay."
Will you guys help me through the troubleshooting process from this point? The wiring schematic is very confusing to me. Also, would it be easier to just replace the open Yellow/Black2 <Black/Yellow2> wire rather than tracing the onen wire through the wiring harness?
I'm sorry for writing so much. I'm just trying to explain this as well as possible so i'll get the best possible help and answers. Please feel free to pm me if you need to. Thank you for your time & help. God bless
Old Mar 20, 2014 | 08:17 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Need help with a open in my a/c electrical wiring.
Originally Posted by dperry
My a/c compressor is not running.....
What is the refrigerant charge at?
Old Mar 24, 2014 | 03:13 AM
dperry's Avatar
I Haven't had time to check it. Hopefully i'll get to check it this week. Life has me so busy right now. but let me know how yours was if you get measured befor i do Ok.
Old Mar 24, 2014 | 06:46 AM
snobordboy's Avatar
Moderator
He is asking because the system has a pressure sensor, so if there is not enough of a charge it won't activate. You should be able to find the voltage that the ecu expects to see in the Helms, and test at the ecu wiring and verify if it is working or not.
RIZOBIZERT
Feb 28, 2008 12:25 PM
RHD_BB4T
Jun 2, 2004 04:17 PM
poison
May 2, 2003 12:07 PM
Mark27
Audio / Security / Video
Apr 13, 2002 08:30 PM
CRX-RX
Feb 8, 2002 05:20 PM
