Post Your SOHC greddy Tubo Times (diagnosing my prob)......
Old Oct 29, 2002 | 03:07 PM
boostin4drcivic's Avatar
Default Post Your SOHC greddy Tubo Times (diagnosing my prob)......
ok i know its gonna be different for everybody, but i need some help trying to figure out where i should be 1/4 mi time wise. i ran a shitty 15.4 @ 90.51 @ 8psi although it fell to 5 psi around 4500-5000 rpm. i have greddy 15G, smallest greddy FMIC, turbo xs type s bov, turbo xs mbc, greddy blue box and i ran on my 17s....post ur times along with PSI level, turbo mods, and rims and tires. thanx guys.
Old Oct 29, 2002 | 03:18 PM
horror's Avatar
Default Re: Post Your SOHC greddy Tubo Times (diagnosing my prob)...... (boostin4drcivic)
my friends runs 14.1-14.3, on his 99ex with the greddy kit on 9psi (vafc hack), intercooler, bov and oil cooler. no rear seat's, stock steelies. everything else is stock
[Modified by poxu, 12:21 AM 10/30/2002]
Old Oct 30, 2002 | 04:26 PM
Default Re: Post Your SOHC greddy Tubo Times (poxu)
c'mon peeps...post ur times and setups
Old Oct 30, 2002 | 06:25 PM
98civicEX's Avatar
don't know if this helps but it's my 1/8 times
8.81 at 80mph slicks
9.17 at 79mph 15" SI's
98 d16y8 12psi stock internals full interior vafc-hack....still much thanks to VTC_CiViC , the one who introuduced me to boost!
Old Oct 30, 2002 | 07:53 PM
M.A.R.C.'s Avatar
Default Re: Post Your SOHC greddy Tubo Times (98civicEX)
same here... i caught the boost bug from david... can't wait to hit the track with my setup (T3 60 trim!)
Old Oct 30, 2002 | 08:25 PM
skilzz's Avatar
Default Re: Post Your SOHC greddy Tubo Times (CivicRyda2k)
see sig...
with 10-11psi once, I ran 13.6 @ 103.5MPH (mucho detonation!)
[Modified by maddskilzz, 12:27 AM 10/31/2002]
Old Oct 31, 2002 | 10:07 AM
autoEXturbo's Avatar
on my automatic sohc 00 coupe, i ran a 14.9 at 95 @5psi. I was very impressed considering i was running 17's before.
Old Nov 4, 2002 | 07:15 PM
Default Re: Post Your SOHC greddy Tubo Times (autoEXturbo)
Old Nov 4, 2002 | 07:55 PM
Hammett's Avatar
He inspired me too
Old Nov 4, 2002 | 07:57 PM
CzanSOHC's Avatar
Default Re: Post Your SOHC greddy Tubo Times (Hammett)
are you still using your stock clutch? Thats is prolly the problem.
Old Nov 4, 2002 | 09:26 PM
TURBO91REX's Avatar
Hey Eric whats up man, Im sure you know this but with the same setup, I ran a 9.1 @ 80 mph in the 1/8 and the EXACT same intercooler . Just swap your 17's out for set of stockies and lower the pressure and see why your boost is leaking or whatever is happening, oh by the way when i get my crx back ill give you a ride and let you see some REAL HONDA POWER MUAHAHAHAHAHAHA.
Jason
[Modified by TURBO91REX, 6:27 AM 11/5/2002]
Old Nov 4, 2002 | 10:01 PM
Boostin Ex's Avatar
Default Re: Post Your SOHC greddy Tubo Times (TURBO91REX)
Im running 98 civic Ex with stock motor @7psi
Best time so far is 14.2@98mph
My mods are greddy turbo kit
greddy intercooler
greddy type s blow off
msd inline fuel pump
Vortech Fmu
greddy profec A boost controler
Aem cam gear
Jacobs ignition
Act clutch
Some kind of under drive pulley
Custom 2-1/2 exhaust w no cat
Old Nov 4, 2002 | 10:15 PM
yoshe95si's Avatar
Default Re: Post Your SOHC greddy Tubo Times (Boostin Ex)
My boost drops also. But I heard it was because my exhaust has a bad leak in it. Never fixed it and I haven't ran it lately. When was the last time you did your valve lash? Do you have colder spark plugs? Is your BOV go off easily? Try tightening your BOV more. That way it will hold more boost. I've seen a CX with my exact same setup but interior dumped and he ran a 13.5 on street tires.
Well here's my specs....I know I could've done better. My tires only had 8psi, which was too low for my drag radials. And our ghetto *** track doesn't have an air pump.
[Modified by yoshe95si, 11:22 PM 11/4/2002]
Old Nov 5, 2002 | 11:16 AM
M.A.R.C.'s Avatar
greddy intercooler
Vortech Fmu
Aem cam gear
Jacobs ignition
Act clutch
DAMN 14.2!?!? that's good for 7psi. my cousin just ran his si @ 7psi and ran 13.9/14.0
Old Nov 5, 2002 | 12:35 PM
CzanSOHC's Avatar
greddy intercooler
Vortech Fmu
Aem cam gear
Jacobs ignition
Act clutch
That is pretty hard to believe at only 7psi. Was the interior gutted? I don't beilive those times at 7psi. sorry.
Old Nov 5, 2002 | 12:57 PM
Hammett's Avatar
Default Re: Post Your SOHC greddy Tubo Times (CzanSOHC)
Lets see the timeslip
Old Nov 5, 2002 | 01:07 PM
M.A.R.C.'s Avatar
i'm saying... i'm pretty sure it was gutted, and on slicks or something
Old Nov 5, 2002 | 01:37 PM
KevronsEG's Avatar
my custom setup ran me 14.800 with 6psi on crx si motor
Old Nov 5, 2002 | 06:35 PM
synergy004's Avatar
Default Re: Post Your SOHC greddy Tubo Times (CIV616)
1991 crx SI, 95 EX motor stock bottom/stock head. Starion intercooler, pieced together piping, XS BOV, Greddy turbo kit.
13.78@102 mph 1.89 60ft on lensos/22 inch slicks BEST
13.89@102 mph 1.90 60ft " "
13.90@101 mph 1.91 60ft " "
clutch started to slip seriously after 3 runs on 8 psi running really rich 110 octane fuel and no VTEC engagement (fields VTEC controller crapped out)
Old Nov 6, 2002 | 04:16 PM
Default Re: Post Your SOHC greddy Tubo Times (synergy004)
man u guys make me feel like i cant drive worth a **** with these times...although some of these sound a little rediculous...like a 14.2 on 7psi . ah well, ill be ordering a test pipe and some drag radials for my next runs...too bad theyll be next season. keep em coming...oh yea jason, i cant wait to ride in the rex when u get it back. p'z
Old Nov 6, 2002 | 06:44 PM
VTC_CiViC's Avatar
He inspired me too
lol.. I have a following
<-- 98 EX on GReddy- 14.63 @ 95.01mph @6.5psi -- 14.13 @ 102mph @~10-11psi (2.4 60')
Old Nov 6, 2002 | 11:37 PM
TURBO91REX's Avatar
Default Re: Post Your SOHC greddy Tubo Times (boostin4drcivic)
Oh dude im not sure when ill be getting the rex back, but the shop is wanting my intercooler piping and I cant get it down to louisville anytime soon. But I have a video of me running the 1/8 mile and getting that 9.1 @ 80 Mph, roughly 14.1 or .2 at maybe close to 100 mph. Hit me up and ill show you whats up, oh, I just had an insight, maybe those 4 doors are putting a damper on the times due to the weight, but it couldnt be by that much. As the crx only weighs, 1974 w/o me . Late
Old Nov 7, 2002 | 11:53 AM
M.A.R.C.'s Avatar
Default Re: Post Your SOHC greddy Tubo Times (VTC_boost-less_CiViC)
He inspired me too
yes mastah...
hey dave i'll be out there tonite at the spot lemme know if u going. my clutch is getting weak but so is my wallet so i'm gonna have to deal with it
Old Nov 7, 2002 | 11:56 AM
VTC_GsR's Avatar
He inspired me too
Wish I could afford to catch that virus ::sniff::
Old Nov 7, 2002 | 12:23 PM
VTC_CiViC's Avatar
Yea I'll be out there tonight
greygoose
Apr 15, 2008 10:59 AM
greygoose
Apr 10, 2008 10:19 AM
boostincoupe
Sep 30, 2004 02:29 PM
98teg
Jun 14, 2002 10:15 PM
SilverS
Nov 6, 2001 08:45 PM
