22mm front SB and rear 22mm SB??????
Old Mar 18, 2014 | 11:27 PM
vega5415's Avatar
Default 22mm front SB and rear 22mm SB??????
Hey I would like to know If any here has tried this set up on their EX. Stock front sway bar (22mm) and an ITR rear sway bar (22mm).
1) Did it work for you?
2) What were the characteristics of the car?
3) Would you recommend this set up?
ETC....
all thoughts welcomed, even the ones were you make fun of me, question my ignorance, and my personal favorite, telling me to do my research. LOL
Old Mar 18, 2014 | 11:51 PM
Marvin1985's Avatar
Default Re: 22mm front SB and rear 22mm SB??????
I prefer 24mm up front and 22mm rear. IMO best for auto X
Old Mar 19, 2014 | 12:11 AM
tony_2018's Avatar
Fish Twig
ETC....
What do you mean by "work for you"?
What are you plans that need you to assess this kind of setup?
Can't recommend something without knowing your intentions
Old Mar 19, 2014 | 02:40 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
For a coupe, this setup would be pretty good. You'll have a good balance, depending on your spring rates and other mods. What are you doing with the car?
Old Mar 19, 2014 | 04:15 PM
vega5415's Avatar
its being daily driven and the occasional autoX
Old Mar 19, 2014 | 04:18 PM
vega5415's Avatar
at the moment I'm running H&R springs and TruHart sport shocks, with skunk2 camber kit front and rear
Old Mar 19, 2014 | 04:27 PM
B_Swapped93's Avatar
While few ppl mention it seriously look into the ASR 32mm hollow bar I'm runing that with no front bar on my time attack DC2, I can give you the rest of the specs but it's a full time track car. But that bar can be set to feel like a 24mm on it's lowest setting if you go with the .095 wall thickness and it's 1/3rd of the weight of the 24mm asr one before you look into RSB's etc get a proper coilover system or better tires.
here http://www.asrparts.com/94-01-integra/
Old Mar 19, 2014 | 04:36 PM
tony_2018's Avatar
Fish Twig
Truthfully the type r setup is perfect for me but everything else needs to be in the equation as well: tires, swaybar, springs and struts so that it can either be a beast coming around the corner hard or slide a little on the rear, etc...etc... Not everyone prefers a bigger sway bar to get what the want on the track. We had this discussion on team-integra.net and believe it or not someone actually downgraded to a 13mm rear swaybar. Different strokes for different folks.
So technically its all personal preference.
Old Mar 22, 2014 | 09:26 AM
vega5415's Avatar
I just came across a 19mm rear sway bar I'll try that for the mean time and see how it works and just go from there. Thanks for the input you guys
Old Mar 22, 2014 | 09:38 AM
Hugh_Jorgens's Avatar
My friend did a 19mm invidia setup on his 98 hatchbox. It was ok.
I still prefer a stock 22/23mm bar for many reasons. With your spring rates, though, you may want a bigger bar. Definitely get some subframe support for anything bigger than the stock 13mm bar with your soft spring rates.
You can always disconnect your front bar and/or adjust your rear toe (more negative) to get some rotation going during autocross. Negative toe isn't something I'd recommend for a DD.
You can also add a little neg front camber and stagger tire widths to get rotation.
96-00 coupes are so damn long that you really need to be creative to get them to not understeer.
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
itstahirj
Jul 12, 2007 11:02 AM
triple
May 23, 2006 03:45 AM
Chompn57
Sep 10, 2004 05:28 PM
ej1civic
36
Jul 23, 2003 08:20 AM
