Axles
Old Oct 29, 2002 | 02:31 PM
Cocheze's Avatar
Default Axles
I have a '95 accord with a '98 F20b swapped in it. When i finished the swap i put the F20 driver's side axle in because the inner joint is a yoke(female) instead of a male and I didnt swap the intermediate shaft. I didnt notice it at the time but the f20 axle is a smidgen too long so my bearing is screwed. So my question is that i want to get a '95 d.s. axle and put like a '97+ prelude inner oon it cuz as far to my knowlede, the only real big differences to the f20 and the h22 are basically internals....so would that hybrid axle idea work?
Old Oct 29, 2002 | 02:54 PM
Accord94DX's Avatar
Default Re: Axles (malice)
i run a hydrid prelude axle setup on my accord. You can actually use all accord axles with your setup...
I run a prelude transmission with prelude intermediate shaft. On the driver side I run an accord axle with prelude inner joint. No problems.
Old Oct 31, 2002 | 07:04 PM
smokin rubber's Avatar
Default Re: Axles (Accord94DX)
I understand that the transmissions are the same, but I thought if the drivers side was accord then the int shaft should be as well ect..?
pali
Jan 6, 2019 07:22 PM
H23 Power
May 24, 2006 09:07 AM
willywonka
Jul 15, 2004 06:07 AM
typertn
Jun 27, 2004 05:22 PM
jdmcivicferio
Dec 24, 2002 01:15 AM
