Suspension & Brakes Theory, alignment, spring rates....
Question about alignment after brake conversion
Old Mar 17, 2014 | 10:01 PM
Marvin1985's Avatar
Default Question about alignment after brake conversion
I have 01 integra gsr/ls brakes on my 99 civic hatch. Full disk. Now I had an alignment prior within 300 miles of swap. So far haven't driven the car on new brake setup.
I've heard that integra knuckles are taller and mess with my camber when swapped onto a civic over dx knuckles.
My question is how much positive camber do the teg knuckles throw off camber from the dx knuckles? I don't wanna spent $100 for another alignment when I can adjust my uca's myself a lil. Any experience would help. Btw I'm lowered on 15x7.5 +30 with 205/50/15 tires
Old Mar 18, 2014 | 06:28 AM
redlinetuning's Avatar
Default Re: Question about alignment after brake conversion
It's not the camber you should be worried about. If you swapped out the trailing arms too then the toe settings might have changed therefore you should get an alignment done.
Old Mar 18, 2014 | 02:14 PM
Marvin1985's Avatar
My rear trailing arms are still stock. I have Scarebird disk brackets for conversion. (Google if you don't know bout it) my only concern is camber in front from the Knuckle swap. I'm gonna do a string method to check toe in/out.
Old Mar 18, 2014 | 04:31 PM
You'll be fine. You should still get an alignment since you changed the knuckles, which means you would have had to take the tie rod ends off the old knuckles. Then you'll have the sense and knowing that your alignment is good.
Old Mar 18, 2014 | 05:35 PM
TunerN00b's Avatar
He probably isn't fine. Change in knuckle height means change in camber. Change in camber means change in toe, and why the camber is always adjusted before the toe during an alignment.
Old Mar 18, 2014 | 07:57 PM
Hence I said he should get an alignment check. The change wouldn't be all that drastic.
Old Mar 18, 2014 | 08:36 PM
98civdx's Avatar
Master Detailer
You should get an alignment.
The camber may have only changed slighty, but you need to worry about toe as well.
TOO MUCH TORQUE
Suspension & Brakes
Jun 14, 2014 04:02 AM
00ejhatch
Oct 11, 2013 06:05 PM
ahs2m2
Suspension & Brakes
Jun 6, 2005 12:02 AM
parks
Apr 25, 2005 06:31 AM
JrJ93vx
Apr 30, 2003 10:56 AM
