waterpump bad? 94 honda accord lx
Old Mar 17, 2014 | 03:59 PM
Stephen Werda's Avatar
Default waterpump bad? 94 honda accord lx
hey everybody need help with issues i have like car is overheating so i took car in to mechanic they said its head gasket but i highly doubt it just some way to rip me off so i was looking over car coolant is accurate level at times and i did notice that my upper coolant hose is very hot but the lower hose is cold and it looks like its not circulating through lower hose and lately coolant is spraying out of the overflow container it seems like water pump is bad but not sure and it kinda leaks coolant from the waterpump.
so if water pump isnt working then the coolant will overflow to overflow container and if that overflows it comes out the top of the container and flow on to engine bay and then low of coolant will cause engine to overheat? thats what im thinking is happening
my car is a honda accord lx vtec model and its a 5 speed manual
comment what you guys think
thank you
Old Mar 17, 2014 | 05:16 PM
holmesnmanny's Avatar
if when the car overheats the hoses are not the same temperature the thermostat is bad ... get a Honda thermostat only no aftermarkets and you should be good to go
Old Mar 17, 2014 | 05:21 PM
Default Re: waterpump bad? 94 honda accord lx
i replaced the thermostat and its still over heating also there is no coolant running through the lower hose
Old Mar 17, 2014 | 05:33 PM
ej7attack's Avatar
if the system doesn't have any pressure that can cause overheating. also if coolant is coming from the back of the block around the timing cover area you could be losing coolant through the water pump weep hole which would mean that it is bad. if you can get your hands on a compression tester you could somewhat check the condition of the head gasket. if 2 adjacent cylinders have lower pressure than that could mean you have a bad head gasket. a leak down test would absolutely verify that suspicion.
Old Mar 17, 2014 | 05:38 PM
so the water pump is bad ? do you think anything els would go wrong along with it
Old Mar 17, 2014 | 05:42 PM
ej7attack's Avatar
I don't know. is coolant leaking from the weep hole? if coolant is leaking from the weep hole on the water pump then yes it is bad. get a new one. if the motor has been overheated numerous times the cylinder head could have warped causing a head gasket leak.
Old Mar 17, 2014 | 07:13 PM
open the bleeder bolt for a few seconds and then close it when no more air coming out
acbettis
Apr 26, 2018 12:33 AM
themiz816
Jan 12, 2013 08:57 AM
tt3
Apr 9, 2011 07:23 PM
87dxaccord
Jan 19, 2009 01:31 PM
liuczh
Sep 13, 2006 08:35 AM
